Tools/accessories that you ask,Why did i waited so long?
mastercabman
I got a set of spring miter clamp about 6 months ago and i just don't know why i did not get it sooner.
I do a lot of prefinished crown/trim molding and i have to say that those clamps are a MUST!
I used to fight those joints,especialy when it is up to the ceilling.With prefinished you need to be as perfect as possible.
But ever since i got that set,it's been a joy.It's to the point that i almost don't need to nail the joints.I just apply some glue and those clamps puts a lots of pressure on the joint.Of course i still put a couple pins but i get perfect joints everytime.
Or could it be because of the Kapex? [laughing]
Any of you have those clamps?How do you use it?And how do you like it?
http://www.woodcraft.com/Images/products/145691.jpg
Also another tool that i wished that i got long ago is the Fein multimaster.I put that tool on the back burner for years!!!
Peter Halle said:
How bad are the marks that are left by the points?
Yes - same thing I was thinking, they look a bit brutal on the timber they're holding!
I have allways wondered the samething seeing this exact set at woodcraft. It looks like it leaves really big holes/marks in the corners.
Peter,it does leave point marks.but they are not that bad.
I just use a little putty or a touch up wax stick.
woodguy7 said:
Why don't you just use Mitre Bond or whatever it is called over there ?  Apply glue, hold for 10 seconds & solid.  No clamping & certainly no nailing !
http://www.amazon.co.uk/Unika-Mitre-Bond-Kit-50g/dp/9792100024
I have used glue like that before,but maybe i just did not read the instruction or i just have bad luck but those glue just does not work for me.For some reason it doesn't hold or i can't hold the 2 pieces together right long enough for the glue to set.
I have also been going behind guys that has use this type of glue(so they said)and had to rework their crown molding joints.So after that experience i am not sold.
I get mixed results from solid wood cornice, oak is a no go.  The wrapped mdf cornice sticks like,,,, well, you know what it sticks like  [big grin]
I use to have some heavier-gauge miter clamps similar to those, but now I use the ones from Collins.  Very economical and lightweight.
Their holes are similar to an 18ga brad - I touch up with coloured wax.
