Torque PDC18/4
charley1968
Hi Festool, Tyler, Phil
I wonder if there's some kind of list that gives the torque in N/m or torque cut-of ,for given settings on the screwdriver f.e: 1. Gear, 8th cut-off position: 40N/m. Thanks in advance: A.
That's a great question -- I look forward to the response as well from [member=57769]TylerC[/member] or some other rep.
Hi
This figures below are taken from the user guide - the figure I use for training session is 60Nm in 1st gear and 400 rpm. Perfect for the 300-400 mm fixings.........then put the fixing in - easy  [smile]
Motor voltage 18 V
Idling speed* 1st gear 0 - 400 rpm
2nd gear 0 - 850 rpm
3rd gear 0 - 1850 rpm
4th gear 0 - 3800 rpm
Torque for easy/tough fastening
applications
40/60 Nm
Adjustable torque** 1st gear 0,75 - 12 Nm
2nd gear 0,6 - 7,5 Nm
3rd gear 0,55 - 5 Nm
4th gear 0,5 - 2,7 Nm
Chuck clamping range 1,5 - 13 mm
Drill diameter max. Wood 50 mm
Metal 1
Ta,Phil, that helps a lot! Do you happen to know if the transmission of force is linear or is it a differential? Do you understand what i mean? Thanks!
