I made these for my DeWalt track saw but you could easily use with a Festool or other brands. The concept is the jig has a dado that fits snugly over the rib in the track that the saw rides on and has a movable stop with hairline cursor. The primary material is plywood but I have a little solid wood, a t-bolt, a few screws, etc. in them. Cost is very low. One version measures away from the track and accounts for the blade thickness. So you can cut a piece off out in front of the track of the desired dimension. The other jig is for cutting a piece the track sits on top of.
If you want to use these for other track saws, you would not need to modify the jig for cuts in front of the track but you would need to add a second dado to the jig where the workpiece is under the track. So the same idea will work fo all track saws.
