Deansocial
- Mar 14, 2010
Richard Leon said:Dean, what is?
vertical section of a door.
nickao said:Muttons and Mullions
Richard Leon said:... I certainly would not want a vocab discussion to spoil a good thread.
Rob-GB said:I posted a while back that I would do a write up on tenons as there are some areas of misinformation on the net.
Several Fora have repeat posts about the subject and the forthcoming replies are often erroneous. Hopefully this post can be a source of information for beginners and experienced woodworkers alike.
Please take it as it is meant, a way to understand the (possibly) most common form of tried and tested woodworking joint. Of course any constructive criticism will be welcome as this is the first time I have done this kind of writing.
Thank you, Rob.
Lbob131 said:In Fig 11 in the pdf, what process is involved to machine the profiles and leave a tenon that length all in one pass?
I'm thinking Trend Ovolo shoulder Scribe & Profile set fitted to the spindle moulder.
But not possible as a single pass in a spindle moulder?
Apart from the tenon with felders big 250mm diameter slotters.
I did the joinery on an exterior door a while back using the domizilla.
Nick C said:Very nice article, but I must suggest a clarification of the fox tenon. A "through tenon", as the term implies, is taken right through the mating workpiece. It can be wedged or not. If it is wedged, then the ends of the wedges are visible. A "stop tenon" does not go all the way through; neither does the mortise. A "fox tenon" is a wedged stop tenon. The tenon is cut to the required depth, and slotted to accept wedges. The mortise is dug to the required depth, and is undercut slightly so as to accommodate the spreading action of the wedges. On assembly, glue is applied, the wedges are inserted part way into the tenon, which is then inserted under clamping pressure. When the tenon is almost home, the wedges contact the bottom of the mortise, and additional clamping pressure causes the tenon to be spread apart by the wedges as it reaches its full depth. If cut properly, there is a worrisome resistance to the clamp, but finally there is a satisfying "snap" as the wedges seat and the tenon expands. Obviously, some care must be taken when cutting the joint and the wedges, but the result is extremely strong, and highly recommended when a through tenon is not appropriate.
Rob-GB said:Nick C said:Very nice article, but I must suggest a clarification of the fox tenon. A "through tenon", as the term implies, is taken right through the mating workpiece. It can be wedged or not. If it is wedged, then the ends of the wedges are visible. A "stop tenon" does not go all the way through; neither does the mortise. A "fox tenon" is a wedged stop tenon. The tenon is cut to the required depth, and slotted to accept wedges. The mortise is dug to the required depth, and is undercut slightly so as to accommodate the spreading action of the wedges. On assembly, glue is applied, the wedges are inserted part way into the tenon, which is then inserted under clamping pressure. When the tenon is almost home, the wedges contact the bottom of the mortise, and additional clamping pressure causes the tenon to be spread apart by the wedges as it reaches its full depth. If cut properly, there is a worrisome resistance to the clamp, but finally there is a satisfying "snap" as the wedges seat and the tenon expands. Obviously, some care must be taken when cutting the joint and the wedges, but the result is extremely strong, and highly recommended when a through tenon is not appropriate.
Firstly, thank you for taking the time to read it and also to comment, I appreciate that. Second, I apologize for my belated response as on the 1st of April we moved house, such fools that we are, that created a long period without internet access and I am trying to play catch up on many fronts. [embarassed]
May I quote from the PDF "This method is often referred to as Fox Wedging, that is a method of wedging stopped mortise and tenon joints."
In the UK this terminology is often used to describe the method of wedging not the actual act of producing a "Fox Wedged Stopped Mortice And Tenon" I think this, rather like the earlier debate on "Muntins and Mullions" is down to differences in language and geography and how our common language but disparate experiences sometimes fails us when trying to get an idea or information across. Unfortunate and oft frustrating but I think I shall let my writing stand, as, it is an honest piece based on my training, experiences and practice.
Regards
Rob.
