Trion wear plate
jeffinsgf
Retailer
Northeast Ohio
My Trion jig saw gets used for just about everything.  It is my best option for cutting metals, as well as contours on wood.  I recently noticed that the sole plate is pretty scarred up and has a lot of metal particles embedded in it. I don't want to scar up my wood projects with the metal chips.
I am going to order another sole plate, which I will use strictly for woodworking and use the old one when cutting metal.
Has Festool considered a harder material (phenolic, perhaps) for the sole plate?  Am I being particularly rough with my saw, or is this common?  It doesn't seem that anyone considers it common, because I don't find the sole plate on the internet sites that sell accessories.
Jeff, I don't think that the sole plate for the Trion is a commonly replaced item based on my experience.  You can order spare parts, such as this item, directly from our service department.  Regarding the material used in the base, I will pass the suggest/question on to our Product Management team.
Thanks.
I'm actually in about the same situation as you. I cut a fair amount of light gauge metal. The base plate is scarred up a bit and slightly rough. Before cutting metal regularly with me Trion it never used to leave marks on wood. I've gone to putting a layer of painters blue tape on the base plate when I cut wood. I have to replace the tape from time to time but otherwise it's ok. I think the fine metal shavings are the issue.
I have purchased sheets of a slick coated adhesive that is designed to go on the plates of jig saws. I do not remember the name of the product but I got it at Woodcraft. It creates a protective barrier and is quite slippery. You might do a search of their website. I think it might be just what you are looking for and the price was quite reasonable. Certainly cheaper thn a new plate.
Hey!  I like that idea.  Thanks.  Time to Google. [smile]
