TS 55 Blade Speed Adjustment - how to know what speed is best?
MikeDVB
Hello!
So I just picked up a TS 55 a few days ago and prior I had been using a Bosch Circular Saw [with no speed adjustment].
That said the TS 55 does have a blade speed adjustment and I'm not entirely sure how to know what speed I should be using.  I know that it would vary with material - but how does one know whether to use a higher speed or a lower speed?
I do have the 3 blades from few teeth to lots of teeth although I'll most likely be using the middle one most often.
It looks like the speed 6 is within the recommended range for everything I want to do [hard and soft wood] - no plastic or aluminum or anything.
I run it on 6 for all types of wood and sheet goods with every blade. Exception being cutting plastic for which I use 2 or 3.
I have not ever put in the effort to experiment though.
Yeah the supplemental manual suggests 4-6 for just about everything but metal and plastic.
Speed # 3 works for the majority of plastics that I cut.  I have other saws that I use for aluminum although I rip up to 1/4" aluminum on my table saw with no speed adjustment, same for my chop saws.  That being said, I keep aluminum/plastic blades in all my stationary equipment...Amana's Blucoat blades are fantastic.
Cut a lot of aluminum with my 75 last year. Started off at speed 4 but soon increased to full speed with no visible penalty. I did frequently lube the blade with waxy stuff meant for that.
So, as most do, I run the saw at full speed for everything but plastics.
IndyMike said:
So to cut acrylic - 2 or 3?
I'd start at 3 and if you're melting the acrylic too much then bring it to 2.
Porcelain is 1 with a diamond blade.
Cement board is 3 with a PCD blade.
Aluminum is 4 or 5 with an aluminum blade.
Wood is 6
