I have a UK TS 55 EBQ (491 596)
When I pull up the fast fix lever, the blade doesn't lock and still spins almost how it would without the lever pulled, but with just a bit more resistance.
It's quite old and out of warranty.
I've been told it could be dust not allowing the mechanism to work. If so, where would I blow that out from? I've removed the cover plate and vacuumed inside that but there wasn't much dust.
It has also been suggested that some sort of "shaft" may be broken. If so, what exactly would be the name of the spare part?
As it's out of warranty, I'm thinking twice about whether I want to get it repaired or looked at. It works fine and I can change the blade by holding the saw against a piece of wood.
Any help would be appreciated.
