TS 55 REQ 45 degree setup
MTbassbone
Does anyone have any tips on setting up the TS55 REQ to cut perfect long miter cuts. The saw tilts to up to 47 degrees and I don't think there is a positive stop at 45 degrees. Same is true when returning to 90, as there an extra degree in the opposite direction. I know you can do the test cuts and make a mitered box and check the joints. Is there a way to do it without making a box?
