I bought a TS 55 REQ during the last refurb sale. It has the green "G" sticker so I assume it's had the recall performed.
Recently I've noticed that after cutting with the track it doesn't retract fully until I remove it from the track. It doesn't matter if the track is clamped or not. I have two 1400 tracks and it happens on both. It gets stuck with about 3-5mm of the blade sticking out (pretty much one tooth's worth). It doesn't really seem to matter if I push to the left or the right or center during the cut.
Playing around with it the only way I can reproduce is if I push the riving knife away from the saw with very light pressure. It takes almost no pressure at all. Let go and it snaps back to fully retracted. The riving knife wiggles side to side a bit.
I've double checked the free play adjustment on the track sliders and have made sure that the saw base plate isn't in a bind.
The saw cuts great otherwise. It's just a little annoying to have it pop every time I pick it up off the track.
