After ripping the long factory edge of some plywood, getting a square crosscut from the referenced rip cut is proving to be difficult.
I've had this issue pretty much since I've had this saw and 1400 rails for about 2 years now but have always just worked through it. Using several different precision squares (Woodpeckers) to set the rail 90 degrees from the original rip cut always produces a cut that is out of square. It is about 1/8" over the span of 48".
This week I have really tried to solve the issue because I would love to get a TSO or Woodpeckers guide rail square one day. I watched Peter's video and read the supplemental manual. The saw was pretty much calibrated based on these methods (front saw blade tooth touching and back saw tooth a paper width out).
If I make a mark with a T-Square and just put the splinter guard on that mark, it seems to produce a cut that I can live with. This leads me to believe it is the rails. This occurs on both rails but what are the odds that I received two bad rails?
I called Festool yesterday and was surprised at what I was told. The guy I spoke with said that the TS 55 and rails are not precise enough to get square cuts without the use of their parallel guides and MFT table. He said third-party squares such as TSO and Woodpeckers are not precise either. In other words, and this is what I repeated back and he agreed, you plop down ~$600 for a saw, another ~$300 for some rails and you're still expected to pay another ~$900 to get some parallel guides and an MFT table just to get an accurate crosscut.
So at this stage, I'm not sure what to do. I definitely don't want to spend that kind of money. I'm contemplating selling it and getting a Makita, DeWALT or Triton and use the extra money to get some other tools for the shop. Not bashing Festool, it's just been a frustrating battle trying to get square cuts and was hoping to get some answers with Festool. That's why I am posting here instead to see if anyone else has experienced the same issue. Love my Domino by the way. Game changer for my work.
