Crosscutting a 4" thick board I consistently get an slightly oblique angle instead of a right angle on a deep cut.
I'm using a TS 55, a 32" guide rail, and quick clamps. I measured the TS55 blade as exactly 90 degrees to the base. I clamped the guide rail with two quick clamps and I pressed down on the saw when cutting. It seems like the guide rail is tilting the saw slightly away from the cutting line.
Is my technique off? Could the guide be at fault? How do I fix this problem? Thanks in advance for any help.
