onocoffee
Getting the TS55 FEQ and one of the first tasks I'm planning is ripping some 1/2" oak planks. Should I also pickup the wood ripping blade? At what point should I buy this blade?
onocoffee said:Getting the TS55 FEQ and one of the first tasks I'm planning is ripping some 1/2" oak planks. Should I also pickup the wood ripping blade? At what point should I buy this blade?
Crazyraceguy said:It depends on the blade you already have. The one that comes with the saw is a fine finish 48 tooth, which is hardly ideal for ripping anything. The "universal" blade, with its 28 teeth would be much better.
I would say it probably depends on how much ripping you will actually do. I would step-up to the dedicated rip blade, if it is more than rarely, especially if you need to go thicker.
I never understood why they don't ship with the universal blade? Doesn't that seem to be the most versatile for the most people?
Packard said:I am of the opinion that track saws are best suited for sheet goods like MDF, plywood, OSB and particle board.
I am also of the opinion that track saws are mostly used for those sheet goods.
And the fine tooth blade that ships with the saw is generally what you would want to cut those sheet goods.
But please note: “I am of the opinion” is basically based on my use of the saw and seeing videos of it being used. I don’t have any data to say what percentage of the cuts are made on sheet goods.
Packard said:Crazyraceguy said:It depends on the blade you already have. The one that comes with the saw is a fine finish 48 tooth, which is hardly ideal for ripping anything. The "universal" blade, with its 28 teeth would be much better.
squall_line said:Packard said:I am of the opinion that track saws are best suited for sheet goods like MDF, plywood, OSB and particle board.
Depends on what you watch or follow online. Almost all of the furniture channels I follow on Youtube are building out of slabs and hardwood and use track saws to cut them down to size. It's one thing to not want to hump around an awkward (but not terribly heavy) 4x8 sheet of plywood to a table saw, it's another entirely to try to wrestle a 200 pound, 10-foot long slab of walnut onto a table saw rather than just straight-line ripping it with a track and saw.
And this isn't limited to the TS75, either.
