cliffp
- Jun 22, 2012
I realise this may well be a problem with my technique but when I cut using the MFT/3 and attached guide rail (I haven't tried without the MFT/3 attached guide rail for comparison) I get a non square cut. The error is what you would expect to get if you set a small negative angle on the saw. When I investigated the way the rail sits in the work piece I could see that the two rubber strips that run along the length of the rail appeared to be lifting up the rail relative to the edge of the rail where the cut is made. It occurred to me that if this allowed the cutting edge part of the rail to droop, there would be a negative cut angle. I am suspecting that this is the problem but wonder how to avoid it? I can't imagine the user is expected to put a spacer under the right hand edge of the rail. I have tried applying some pressure over the left hand side of the rail to squash the rubber flatter but this does not eliminate the problem, probably because I didn't press hard enough (and I wouldn't have thought this was a very good solution anyway). Maybe I shouldn't be putting any pressure on the work piece (with the rail) at all since it is firmly against the top and the fence.
Any suggestions as to where I am going wrong would be much appreciated
