Finally I got my “NEW” TS 55 REQ the other day. Just to clarify: “NEW” means refurbished – so please don’t expect fresh from assembly line tool. And some things where missing so check it.
I hope it’s ok if I post it here, I would like to get the more experienced users opinion on some of the saw performance aspects.
When I placed my saw (fresh out of the box) on a flat surface the sole plate wobbled diagonally as if it was warped. Upon further investigation I discovered that whenever changing the bevel angle the front of the saw does not stop exactly at 0 (slightly below) thus causing this phenomenon. I am not pushing down on it, not even touching it, saw is sitting on its own, flat on the surface – if I lock the front and back knobs it will wobble unless I slightly lift front bevel and ensure it’s dead on 0.
Are you experiencing this as well?
Also I noticed that the spring loaded riving knife moves freely side to side, more than the width of the blade. Manuel doesn’t say anything about it. Is this normal?
Your comments will be greatly appreciated.
Cheers.
Cheers.
