bentrail said:
Hello I have issues with my track saw every time i connect 2 tracks together my track saw wont want to slide across the 2nd track
any help?
Make sure you have the rails connected correctly - see other threads here on this topic and/or youtube for alignment tips.
What you may not find mentioned - check/remediate below (in order of priority):
- the rib the saw rides on is not the exact same width
=> check which rail the saw goes "harder" when the cams are tightened, then mark this rail and always use it as the "first" rail
- as sold, the rails do not have treated edges, the sharp edges of the green strips can "catch" the saw when moving to the "second" rail
=> chamfer the edges of the green strips with a knife slightly, so there is no sharp edge involved
=> optionally also slightly chamfer the aluminum edge (by 0.2 mm is enough, just to avoid a sharp edge)
- the rails can be joined in such a way the "second" rail flat side (where the saw rides) protrudes above the "first" rail at the join point
=> there is not much you can do, except trying to join the rails in a way the "second" rail is level or, ideally, slightly below the first rail when held in the air
