TSC 55 + Parallel Guide?
DavidCBaker
I know it works with the TS 55, but does it work with the cordless version of that saw? Thank you!
The parallel guides attach to the rails. The saw will clear them at all but full depth cuts. At least with my Woodpeckers parallel guides I loose about 2mm of depth, using a corded TS55 REQ.
[member=8542]David[/member] , if you were asking about the Parallel GuideS then you have an answer above.  If you were asking about the accessory that has the two rods that attaches to the saw itself then yes it does.  It used to be called a Parallel Guide but now is named in the catalog as a Parallel Side Fence.  Part number 491469.  Same for corded or cordless.
Yes, I was asking this, actually. So it works--thank you so much, sir.
