TSC 55 setting blade depth help
Dash
Just setting up the saw...  I can't get green indicator to line up with the marks on the ruler sticker .
Example: Trying to set the blade at 10mm. I can only get FS marker  to land on 9mm or 11mm. I tried the sprung loaded adjusting knob which is supposedly for very fine adjustments, but that doesn't seem to do anything noticeable. The knob doesn't seem to need the allen key?
Thanks for any newbie advice.
I personally gave up on that depth marker system week one.
It is horrible at best IMO! Considering what a game changer the saw and system is in general I cant believe how lame that set up is.
I'm pretty sure that the detents are 1 mm apart, but I could be mistaken. I can't check physically right now.
The fine adjustment knob doesn't adjust the position of the green stop - it just changes how far down the saw can plunge. Lower the saw and you'll see where the motor/blade assembly contacts the fine adjustment knob. No tools required.
