Hi guys,
I have recently purchased a tsc55 and only used it a handful of times, mainly cutting sheet material, trimming doors, cutting worktops. The first few times using it I had no problems whatsoever. Now when I go to use it sometimes it works, other times I pull the trigger and 2 red lights flash on the battery indicator and it won’t start. Today I would make one cut, return the saw to the start for the second pass and it wouldn’t work. I would try the trigger 4 or 5 times then it will work again. I make a couple of cuts fine, then again it doesn’t start first time. Batteries are fully charged and the saw isn’t overheating.
I’m thinking it could be a loose connection or something along those lines?
Any feedback would be appreciated!
Jonny
Jonny
