At the risk of harping on about Z-chairs, here are a couple more that I have built recently.
The first is a carver, designed to match my zigzag dining chair. Its miters are 27.5?, giving 55? joints. They are reinforced by a single through 9.5 x 32 x 65 mm tenon. The tenon's mortices were routed on my mortising jig, using a 3/8" spiral bit with a 2" cutting length. The chair's seat/back assembly is supported by the upper of two stetchers, which join the two Z-assemblies. The back's stiles are screwed and dowelled to the rear end of the arms.
The second chair, designed for admiring the view from your penthouse suite in the Trump tower
, has
50? miters joining the feet to the legs, and 40? miters joining the legs to the arms, so that the chair reclines, with its seat at 10? to the horizontal. Its miters are reinforced by three locking tenons, in the same way as the original Zigzag dining chair. This chair is made of Rose Gum, with Jarrah laminated backslats.
David
David
