Ug wings - only need one
HowardH
Albuquerque
Can one order only the right side of the Ug wing set?  I want to use it as a long material support off my MFT/3.  I saw a video of Eric (erock) using one for that purpose but I imagine he just attached the right side unit off the set he has for a Kapex. I don't need another MFT/3 as a cutoff support table but if Festool won't break down a set, I may have to do that.
that's perfect... not cheap... but perfect.  I presume it will drop right into the profile and be the same height as the table top.
The main part of the UG extension will be at the MFT/3 table top height, but the 'fence' part of the extension sits up higher. Yes it will attach easily to the MFT/3 without any additional parts.
The UG extensions will NOT work on the shorter MFT Kapex table
[attachimg=2]
[attachimg=3]
[attachimg=4]
I was wondering the same thing after seeing Eric's video and in searching
I came across this.
http://www.multiblades.com/mft3.html
Didn't buy one but bookmarked it because it looked interesting and I've
been meaning to ask if anyone here has used one with their MFT.
I'm never ceased to be amazed about how someone can take an idea and make it their own.  A set of 2 brackets and folding supports is just a bit over $100.  The Festool version is $385.  You would still have to buy an Incra channel to be used at a fence but that's pretty minimal. I'm going to have to give that some thought...
