Grasshopper
- Oct 6, 2014
So I was attempting to install a desk I built for our kitchen. The stud finder located a rather unusual stud in the form of our toilet drain up above.
I drove a few "feeler" nails through the pipe and a couple of pilot screws. I knew I was in trouble when I saw black PVC shavings in the drill bit.
So my "simple install" has turned into a plumbing repair followed by a drywall repair. I suppose if I look on the bright side…I guess I know where the studs are now
I wanted to ask what the best way to repair the pvc plumbing drain would be.
There are 3 or 4 little holes ranging in size from a small pin nail up to a #4 screw size countersink drill bit.
Do I need to cut out the section and place a coupler or something like that, or is there a simple compound that I can use to patch the small holes. I realize this isn't a fun woodworking question, but I assume I am not the first to do something like this, and it is in the way of my woodworking now.
Help!!!
Fun:
Close-up highlighting small holes:
[attachimg=2]
Help!!!
Fun:
[attachimg=2]
