Jerry, yes, all cyclones pull air to its final destination... heavy objects get caught in the cyclone path and gravity drop into the bin. So with NO assistance, all bags pull up the cyclone. The greater the vacuum force, the greater the suction to pull the bag up. For my larger cyclone, I exhaust the final air outside the shop, no final filter, as that air has only microscopic size particles...these are the particles that pose danger to your lungs...its always better to simply exhaust them when possible, vs. trying to filter them.. Filters create resistance, which reduces air flow, the filters are also costly. And no filter is traps 100% of dust in the exhaust air. The smallest particles are what escapes, and unfortunately, they are the ones we should avoid. This is the value of Festool and other Vacs that use large HEPA filters for max. filtration.
Of course the downside is, when you exhaust the cyclone air, you must bring in and equal volume of outside air to compensate, hence why you must consider the climate of your area as heating / cooling cost can be substantial if you run the dust collector a lot. This was a contribution from Bill Pentz, who has spent years crusading for better dust collection after years of serious suffering from his lung condition brought on by wood dust. He is a very generous and caring person and really did open our eyes to the dangers of wood dust. He has a great web site regarding these matters. The woodworking community should applaud his efforts, but yet, on some forums he gets banned....which is terrible IMO. Supposedly it has to do with comments comments regarding other companies products...
Woodnerd has built an excellent solution to hold the bags down... I actually dreamed up the same concept, but used sheet metal to create a similar shape. Occasionally, I will forget to put the "hold down" in the drum after replacing the bag, and when the cyclone turns on, it pulls the bag straight up the 8" supply duct...serious suction... Of course, your system is the easiest approach to the problem, don't use a bag
... some wood dust is extremely toxic and will kill animals, so one must beware where they are dumping it.
