mino
Nice write up!Cheese said:...
Last night, I set the torque dial to #Drill and at speed 1 the sound was like the day before but at speed 2 the sound was once again that horrific, irritating high pitched scream.
Earlier today I tried the same experiment and at EVERY torque setting from #1 to #Light On and at full trigger pull it gave me the same non irritating sound whether it was set at speed 1 or speed 2.
Later this morning, I picked up the drill and fully pulled the trigger. The drill was left at the settings I tried last, #Light On and speed 2, the high pitched scream was back. Moving only the torque setting to #13 and the scream went away, I then returned the torque setting to #Light On and the high pitched scream never returned...there's some weird stuff going on.
I also noticed that the #Light Off setting doesn't work as the LED continues to light.
I'm going to work with it a bit more and notice what else is wonky.
It seems the new CXS/TXS series are a prime candidate for introducting a custom firmware profile to limit the torque (and noise) to be enabled using the Festool WorkApp.
I am 99% certain that if an optional "Silent Mode" was introduced which would limit the torque to about 80% of the maximum in exchange of quieter operation that almost everyone annoyed by the noise would be perfectly happy with that while those needing the power would not mind either.
[member=101]Festool USA[/member] : Some food for thought to pass on ..
