Using a Router Buddy with a Festool 1010
barryaclarke
Hello everyone,
    This is my first post so if I am in the wrong section, please point me towards the correct section. I have a Festool  2000 that is permanently mounted in my table and use a 1010 router for odds and ends. I would like to use the Practical Technologies Router Buddy with the 1010. They have a base plate that fits the 1400 and I am told that the bases are close to being the same. Has anyone used the Router Buddy with the 1010 and if so how did it work for you? Or, if no one has tried this, maybe someone can tell me where I can find a scale drawing of the two bases so that I can determine if this is possible or not.
Thank you so very much,
Barry A Clarke
Bourbonnais, IL
The 1010 is a smaller router than the 1400, so I doubt the base would fit both.  I see they have a"universal base" that can probably be drilled to fit any router.  I would check with them to see if that might work, or buy only the universal base first and if it can fit, order the rest.
