using different size blade in ts55
john molloy
where I get my saw blades sharpened have there own version of festool blades .the teeth are slightly wide than festool .the guy there said you would not notice the difference in cut as festool blade is 2.2 mm and his is 2.8 which is .6 mm so .3 left or right in cut .he said this is to small to notice on a cut .any one use blades like this and have any feedback
It's going to mess up the anti splinter strip on your track. So it will be off if you go back to a festool blade which is thinner.
