mastercabman
- Apr 15, 2007
I just finished building my new routing table.I am using my MFT 1080 frame and got 1" MDF. Laminated and installed plate,miter gauge channel,and fence.
I even made an electrical outlet w/ a switch so that i can plug my router.
I know that you can use a routing table as a jointer by using shimes(witch i have)on the left fence and adjust that fence straight with the bit.
Of course there is limitation on the size of the bit,but i was thinking about doing edges.I don't have a jointer.Maybe one day i will invest in one but right now it's not easy.
So,i would like to know from anyone who has used or using their routing table to joint edges.Is it ok? Or should i look at a small jointer?
