ChuckS said:Nice. You just have to mill thr mortises on the aprons. I presume the tenons on those buttons are smaller than the standard domino mortises
hdv said:I like that idea!
But why did you put the tenon so close to the edge of the blocks? Was there a specific reason for that?
luvmytoolz said:The buttons look to be a very snug fit unless I'm mistaken and won't allow for wood movement, or are you cutting the mortises on the wide setting to allow sideways movement?
hdv said:That makes sense. Most buttons I have seen were indeed just blocks of wood with a rebate and a screw hole.
After that, I have used the 6mm Dominos, tight in the blocks, wide in the apron.
Crazyraceguy said:hdv said:That makes sense. Most buttons I have seen were indeed just blocks of wood with a rebate and a screw hole.
That is the way I used to do it, before I got the DF500. I just cut a groove down the entire length of the aprons, just like a drawer side, and a matching rabbet on the clips.
