Dave Ronyak
- Jan 23, 2007
If you have decided to buy another vacuum machine to supplant the Mini, I suggest you also consider those made by Fein. They have recently revised their line to incorporate a variable speed function. I have an older Fein Turbo II which I frequently use with my Festool products, including my OF 1400 router and TS 55 saw. The standard Fein hose is longer and larger in diameter than the Festool 27mm hose, but is not anti-static. This has not been a problem for me except when using a vacuum with my Bosch 4 x 24 belt sander which will provide quite a stream of static shocks if used in the winter time (low humidity) without a static dissipating hose and vacuum. To my ears and those of my wife and my son, the Fein Turbo II is noticeably quieter than the CT 22 E at full power.
Dave R.
Dave R.
