Vaccum cleaner CTL Midi
par
Hi. The first few times you use this vacuum, it seemed that aspired better.
Now it seems that sucks less and less.
I have it connected to the machine Virutex TM33L.
For better aspiration, it is recommended to use another hose, a hose shorter? Thanks.
Check for clogs in your hose or other obstructions.
Also, check your bag to see if it's full.
Shane I don't thinks the guys Dutch..
also worth giving the bag a shake with your hand over the dust port opening as the pours tend to get clogged with fine dust and reduce suction. I actually fire up the compressor, cover the dust port hole and give the outside of the bag a few blasts with the air gun to clear the pours and i am usually back to full suction goodness.
