stvrowe
- Jan 27, 2007
One of the annoying things about hooking vacuum or extractor hoses up to power tools is that most hoses have ridges. These ridges tend to catch on corners of work pieces and the MFT table. I decided to fix this annoyance by installing 1-1/2" expandable sleeving over the vacuum hose and plug it cord. This eliminates all drag and catching on the corners and so far I have been very happy with the solution. I almost went for the heavy duty abrasion resistant sleeving however, it was not available in neon green. Only time will tell how well it holds up to abrasion. I sealed the ends using Rescue Tape which only adheres to itself and it provides a conforming tight fit to the hose and connector. I also inserted the plug-it cord inside to eliminate having to tie it off to the hose.
Steve
Steve
