erock
- Apr 29, 2010
T.Tom said:As usual, I find your videos informative and entertaining! I see DIY Sysports in my future as I'm getting more "Festoys". (Love the Carvex!! The LR 32 may be my next purchase.).
After watching this video on the Sysports, I noticed the air line and and vac hoses mounted above your work surfaces. Would you please comment on the length of the vac hose and if it is 27, 36, or 50 mm? It looks like a 27mm to me and you have joined two or more together. Festool has several connectors and it would be helpful to know what you used or prefer in your setup. Going to run air drops in my garage soon instead of dragging the hose(s) from the compressor. A search on the FOG shows many DIY boom arms for supporting the vac hose and I have thoughts on that subject also. Also considering a six foot version, Paulk style, work bench to double as an out feed table for my table saw and as an assembly table.
My grandfather was a professional carpenter. I'm a professional sawdust maker.
MAN ! I'm sorry. I missed this post.
Here is a pic of my boom arm.....
I have two 27mm hoses connected to my CT26. I took the tool end off of the hose that connects to the CT and replaced it with
a Hose Sleeve-Rotating Connector (the same connector that goes into the CT) part number 452 892, then used a Anti-static connector sleeve, part number 493 047 to connect the two 27mm hoses.
Hope this helps man. So sorry for taking so long in responding !
Eric
