Richard/RMW
- Jul 11, 2010
I think this will be the winter that I finish my little 10' X 12' shed/shop interior. The building was a stick-built shed on the property when we bought it, I dragged it about 20' across the yard, spun it 90 degrees, installed double doors & re-sided it and built the walk-out deck at the same floor level to let me work in/outside comfortably. Overall it is a tiny, really functional and downright ugly place to spend my time, still more of a shed than a shop.
Current conditions are what you would probably expect:
[attachthumb=#]
[attachthumb=#]
The first photo includes my father-in-law at our second annual Crib-Fest (crabs and ribs). The shop/lower deck is kind of an extension of our outdoor living space, another reason to pretty it up. I have weatherproof storage under the deck for sheet goods and lumber, recently made some doors for it and the rest of that should get cleaned up in the summer.
So the plan is to gussy up the interior a bit, including insulation, better lighting, heat and finishing the walls. My main question relates to finishing the walls, I DO NOT want to use drywall, so I am looking for suggestions. The criteria are:
1. Cheap
2. Easily available (Lowes/HD)
3. Durable
4. Light in color, to keep it airy
5. Cheap
I also plan to line the side walls with french cleats starting around 36" from the floor. Only the side walls really have any open area, the rear wall is nearly all cabinets and the font wall is mostly doors. The cabinets will get drawer faces and doors. I prefer a clean, contemporary look, not rustic.
What I am considering is some type of architectural panel system similar to the photo below, but shop-made. Perhaps panels of 24" high by 48" wide, with a small reveal between them or with vertical battens and a reveal in addition to the french cleats?
[attachthumb=#]
Cruising around Lowes website this material got good reviews for appearance and surface finish:
[attachthumb=#]
My current thought is to laminate this onto 3/8" drywall just to give it some thickness and support, and install it horizontally in 2' by 4' panels with battens vertically between the panels and french cleats running horizontally. Exposed fasteners are okay with me, probably stainless screws, and they would mostly be in the cleats/battens anyway. I am wondering if I can get away with ripping the panels, sand and perhaps darken the edges, clear finish and stick them in place?
Would appreciate any thoughts or suggestions, particularly about how finish the edges & mount the panels/battens.
Thanks!
RMW
[attachthumb=#]
[attachthumb=#]
1. Cheap
3. Durable
5. Cheap
[attachthumb=#]
[attachthumb=#]
Thanks!
RMW
