Let me explain:
My woodworking shop is part of a barn, the woodworking portion is actually a log cabin added on that was insulated, wired and used for the previous owner who built log cabins( he used for his shop). It has a concrete floor.
The area I’m putting the Kiln dried Walnut flooring down in is adjacent but has no heat/air although it does have a door I keep open so it doesn’t freeze but definitely has. Temp swings throughout the year being as low as 40-50 in the winter and probably 80 in the summer.
The current floor is the original concrete floor and sitting on top of that is 2x10 joists and 3/4” osb.
I’m looking for a rustic look and wondered about putting down visqueen then the flooring?
The flooring itself I’m thinking of making 1-1 1/4” flooring
Thought about just butting together and leaving a gap around the perimeter for movement and covering a/trim and let the gaps be what they are??
I thought I would vary the width from 3-4” up to ?? I was thinking 12”
Room is about 180sf
Thoughts
Room is about 180sf
Thoughts
