What are the plunge posts on the of 1400 made of ? Rust out of the box new ?
Redcarjoiner
It's been a bumpy start for me after finding that they don't put a few things in the kit that were in the kit when it was first sold ( cut backs ) but shortly after that when I removed that black foam pad that goes around the plunge post it had rusty lines and spots on it.
I wondered if it was bits of orange dust from the orange base plate so I tried a light wipe with a clean cloth but it was not moving. I did not want to believe that it was rust but it would not move so I wiped it with a bit of light oil on a cloth and that took the red away but I am left with little black marks. Have we seen this before ?
I could polish them out but would the post be prone to rust when in use ?
Return it. No matter who the manufacturer is there should be no rust spots on a new tool. I've never bought a Festool new where there were any type of marks on the tool, much less rust or even suspected rust.
I get rust on my posts, both the 1400 and my domino. I assume they are tool steel not stainless.
In my case I blame condensation from temp changes storing then in an unheated shop.
RMW
I keep any silica gel sachets I find in deliveries I get and then chuck one in with routers and router cutters. That keeps the moisture down and stops rust.
I think my of1010 may have had the odd rust mark when I got it years ago but it's fine now.
Nothing  to worry about but if you are worried then return it.
Sent from my ALE-L21 using Tapatalk
I don't know what [member=60804]Redcarjoiner[/member] will do, but rust (or a similar type problem) on the posts of a new Festool $560 router would drive me nuts and I'd take it back. It isn't right to get a new tool that isn't perfect and I've always returned tools that aren't. I love my tools and it's bad enough when I do something stupid to them to make them "imperfect".
I keep the posts on my routers wiped with an occasional bit of Camilia Oil. Seems to hold the rust at bay pretty well. I don't use my routers that often, so I too would not be happy to pull one out of its Systainer and see rust spots on the posts.. [eek]
Wondering if this router has been sitting around in less than ideal conditions for many months or years, when was it manufactured the date is probably on the label.
Hi
If not correct it goes back to the dealer to be swapped out. I replied to your message also.
rg
Phil
I've found camelia oil to be problematic in some instances were I've used it.
One instance was a Lie-Nielsen low angle plane. While the oil left a thin protective coating on the plane, the dried oil residue also glued the adjustable mouth piece in place. I think I spent an hour or more trying to break the mouthpiece lose using s softfaced mallet and wood shims so I wouldn't damaged the plane.
The other unfortunate indtance I had involved the cast iron surface of a machine. I wiped a layer of camelia oil on the surface to prevent rust till I got around to fixing something. When I finally pulled the tool out to work on it, the entire surface I had coated with camelia oil was covered in rust. The surfaces I had wiped down with camelia oil were the ones with the rust problems. Other areas I hadn't wiped down were fine.
  Never experienced any of those issues with it. I have seen WD-40 cause the dried residue issue on some things, but never the Camilia Oil that I have. Maybe the layer you applied was a heavy coat?
As for Cast iron surfaces on a Machine, I've never used it for that, instead, I use Boeshield.
