What do you do for bench dogs
grobin
I have some 3/4 dogs that work but what do you do for 20mm.  Here in the states they are thin on the ground.  I ask because I need to clean up some botched finish on hardwood and am using a lie-nielsen cabinet maker's scraper plane?much faster then sand paper and gets things back to true and level.  But I don't see much in the way of sanding clamps/dogs nor planing.
I either use the Festool Clamping Elements or, if those are too high, I use Qwas dogs.  They have minimal projection.  I also have some ultra-low Rockler plastic dogs, but they are for 3/4" holes so generally if I use them, I push the stock against them to lock them in the hole and use Clamping Elements on the sides to stop lateral movement.
I have a long bench that I bored using a spare MFT top as a drilling guide.  That's where I do the bulk of my planing and the holes are also 20mm.  My MFT, though, is locked to the wall with a star knob and I do plane on there, too (like, a lot tonight...)
when the clamping elements are too high (protrude over the workpieces surface), i shim my workpiece with some flat lying dominos.
You can just add some painter's tape to the dog to help shim it if you need to.  I don't use them enough on my MFT to worry about it.  My Bench has 3/4 dog holes.
I also use the B&D Workmate dogs on my MFT for the most part when I need to.
Grobin,
If I understand your question you need a low-profile dog as to not interfere with your work. I made these "dog-collars" so I could sand some thin material and I also use them when I need a bit more overhang off of the table for the domino.
[attachthumb=#]
Thanks for the replies.  I am going to try the Lee Valley gadget and the dog collars.  Appreciate the help.
