Reiska said:
Most other threads here seem to be comparing the Tormek T-7 and Worksharp to each other, but
- Is the T3 any good? Do you need to have machine power to keep stuff sharp?
- Is using stones and the Veritas guide usable and easy for keeping chisels & plane blades sharp? Which grits would you suggest? Oil vs. water stones? Other guide systems?
Since I'm a hobbyist I don't need to sharpen blades by the boatload nor an extra 5min per blade bother me at all, but if setting up is tedious (machines?) or its hard to get the sharpening done right (stones & manual guide) it will be a no-go.
Currently I have absolutely nothing to sharpen anything but kitchen knives (diamond sharpener for them) so anything is probably a win [blink]
Axminster is having a sale on Tormek T-3's and for some time I've been eyeing the Veritas Mk.II Honing system & stones to go with it.
i have a t7, but the t3 will work fine for you.
you can't run it nonstop, but why would you want to?
the difference in radius on the wheel will not make any
difference to what you are sharpening.
the only real difference is that tormek doesn't make
a japanese stone for the smaller machine, i don't believe.
eventually i'll end up with the japanese stone, and not
even bother with the leather strop wheel.
attachments are the same.
i have a number of attachments, but truth be told, if all
you are sharpening is kitchen knives, the flat adjustable
rest will allow you to quickly sharpen all your knives quite
well.
