Richard Leon said:Reiska, this is just my opinion so others may well disagree.
I would not use the diamond plates as the basis for my sharpening system. I do use a diamond plate for flattening my waterstones, and I also use it for kitchen knives, but not my chisels and plane blades. I prefer the waterstones because they cut smooth and fast, and the water lubricates the cutting action. Waterstones are also preferable for more advanced sharpening techniques such as cambering the blade- if you use a diamond plate for this it is possible to dig the corner into the holes and it makes the process more difficult.
Regarding grit numbers, I don't know how a 1200 diamond stone compares to a 8000 waterstone in terms of results, but I can tell you that I use a DMT duosharp diamond plate equivalent to 220 grit to flatten my 1000 and 4000 stones. The flip side of the 220 grit (DMT refer to it as extra coarse) is 325 grit (coarse) and this is what I use to flatten my 8000 stone.
http://www.dmtsharp.com/sharpeners/bench-stones/duosharp/
If you do go down the waterstone route, buy the individual stones, not the conmbination ones. Yes, it is more expensive but they last much longer per grit so that works out the same. You also have two faces per stone so you can sharpen for longer between flattenings. (I dropped my combination stone on the floor and it split in half, so I ended up with two stones anyway but I do not recommend this!)
Lie Nielsen have two great videos on sharpening with waterstones on youtube which I highly recommend.
The Veritas honing guide is terrific, but with two drawbacks. The first regards the registration jig you attach to it to set the blade length. This is made of steel and the depth stop on it can damage the edge of your blade when you remove it from the jig. Remove this depth stop and use a marker to draw a line instead. Second, always remember to set the microbevel back to zero so you do not inadvertently but a microbevel where you don't want one when you next sharpen.
Hope this helps.
Kev said:promhandicam said:I use a worksharp 3000 and waterstones. I had a T7 but sold it as it and bought the worksharp which for what I want to sharpen - chisels and plane irons is a much better system.
Can you describe "better" from your thinking? Can't see that from my perspective other than maybe quicker and cheaper - but not ultimate edge quality.
Nothing there I didn't know about WS3000. Just your want to be quick and avoid setup and "mess" for a quick edge.promhandicam said:Kev said:promhandicam said:I use a worksharp 3000 and waterstones. I had a T7 but sold it as it and bought the worksharp which for what I want to sharpen - chisels and plane irons is a much better system.
For touching up a chisel, you turn it on push the chisel in and it is done - 10 seconds. If a chisel is badly damaged you can start with 80 grit to quickly establish an edge and then go up through the grits 400 - 1000 - I finish on 3600. No water all over the bench, no dressing the stone, no grading the stone no fiddling about setting the chisel to the right angle - what more do you want to know? With regards to edge quality, you can go up to 6000 solid micro mesh abrasive for fine honing but for me 3600 is quite adequate - enough to shave hairs. At the end of the day I want to spend my time woodworking with sharp tools not spending my time sharpening.
Kev said:This looks interesting ...
http://alisam.com/
The have a blade sharpening sleds (there's several for sale on Ebay).
Reiska said:Uhm, this might be a really stupid question, but does the Worksharp sold in the UK have a 220V motor? (Since I've learned that some tools actualy use 110V there... just to be on the safe side [cool])
Davej said:Reiska said:Uhm, this might be a really stupid question, but does the Worksharp sold in the UK have a 220V motor? (Since I've learned that some tools actualy use 110V there... just to be on the safe side [cool])
As a general rule all workshop equipment in uk is 240v and 110v is for site use , so equipment meant for workshop usually only available in 240/220 v
Reiska said:Well, this is seriously not becoming any easier... Thanks for great advice, but I'm seriously torn between the WS & T-3.
Both are on sale with the base machine costing about £200 and both come with a knife jig and jig for plane blades up to 2" width. And to add to the pain once you get a few accessories for either machine (knife kit, the wide attachment + extra leather disk + extra glass disk + fine honing abrasives for the WS and the hand tool jig kit for the Tormek to match features) their prices still pretty much match at around £370. Which then irritatingly puts both of them very close to the starting price of £489 for the base Tormek T-7 machine with the basic blade jig.
Seeing that all I really need to sharpen are my batch of Stanley Bailey & Bahco chisels, two Stanley 2" plane blades and the occational knife, axe or scissors I guess I could get away with either system, but I'm torn between the convenience of not needing water with the WS and the known Swedish quality & engineering and endless possibilities of the Tormek jigs that don't need today.
Since you can now get a toolbar addon for the WS to use all the Tormek jigs on one I'm wondering wouldn't that make it the more versatile gadget without the water related storage problem and more grits available via the sanding disks than the Tormek two grits on the stone + leather wheel?
Reiska said:If I had unlimited space & budget I'd so be into CNC & 3D printing on a large scale [drool]
