Birdhunter
- Jun 16, 2012
I’ve never seen the Sharpie go through the blue tape.
Me too, not on purpose.Ajax said:Blood
HarveyWildes said:Snip.
I have a pica dry lead pencil, haven't figured out why it's special yet.
GoingMyWay said:I bought a 12ct box of .7mm Paper Mate SharpWriter mechanical pencils last November for $3.32. I still have a few. They've worked well for me.
One downside to them is that they're not refillable. I keep a bunch spread around because I'm always misplacing my pencil.
RobBob said:Doesnt the Sharpie soak through the tape and mark the wood?Sparktrician said:Birdhunter said:I use annotated blue tape to indicate parts that are supposed to go together. It’s just too easy to get mixed up. I normally use a Sharpie marker on the tape. When the parts are glued up, I peel off the tape.
Same here. I go so far as to mark inside, outside, front, back, top, bottom, plus any assembly notes or comments. Once everything is out of glue-up, I peel off the tape and sand lightly.
Sent from my SM-G960U using Tapatalk
How do you guys feel about the mechanical durability of these Pentels? As I stated, I’ve been using the Alvin Draftmatics for years. In addition to not dropping the pencil tip down (they seem to always land tip down kinda like jelly toast), the internal mechanics wear out in about one year. I really like the Alvin’s, but at $15 each, they do get spendy.rst said:I'm with Micheal K, I keep 5 & 7mm in my carpenter pants/shorts pocket. The 5mm works great with my new Woodpeckers Delvo squires as the retractable barrel fits perfectly into the holes. I'm not wild about the pencil Woodpeckers supplied with the set but the Pentals work great.
Naildrivingman said:How do you guys feel about the mechanical durability of these Pentels? As I stated, I’ve been using the Alvin Draftmatics for years. In addition to not dropping the pencil tip down (they seem to always land tip down kinda like jelly toast), the internal mechanics wear out in about one year. I really like the Alvin’s, but at $15 each, they do get spendy.
