What does one call this kind of ID measuring tool?
Scorpion
Peter_C said:
I would call those bar gauges.https://www.rockler.com/rockler-3-i...Atxep5mQeeGdSKheNnjDZFzG5bZO9d_AaAh7BEALw_wcB
Not what you asked, but here is another option, that belongs in every tool box. Come in standard and metric.https://www.amazon.com/Wiha-61620-O...1?ie=UTF8&qid=1538769888&sr=8-1&keywords=Wiha+61620
The folding rule is good (better than the rods imo) but I like the Hultafors Talmeter better. For inside work the tail is used which adds exactly 100mm to the long tape. Both the tail and long end have fine points that can scribe marks on wood.
https://www.ebay.com/itm/Hultafors-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Pinch sticks or bar gauges...thanks!
I have a couple folding rules and they work great.
I like bar gauges and/or pinch sticks because you can lock a measurement in place.  I use them often to compare diagonals, so I don't care what the actual numeric measurement is, just whether they are the same and if not which is larger.
The advantage of 'pinch sticks', using the Lee Valley hardware is that its easy to make the sticks to custom sizes, so you can check diagonals of small drawers or large cabinet carcasses.
