I just realised that I have only random Black & Decker quality brad point drill sets from 1.5mm to 10mm and a couple of different length 20mm ones and now a single 25mm auger drill that I purchased for a gate handle installation yesterday. I also have a few different size Bahco hole saws for larger electric socket/switch bottom installation holes.
I'm wondering
- Are there notably better drill makes and/or types of drills for wood than the run off the mill B&D's and Boschs brad points to invest in? (Though the Colt Rotastop Maxicut forstners are way too expensive @ 50-100€/pcs [eek])
- Any sets you can recommend that would cover larger sizes than 10mm as well? Or would you recommend buying separate drills?
- Are forstner drills worth the money and can they be used as all round wood drills for sizes of 15-35mm (thinking about the Festool Centrotec Zobo set or the Famag 15 piece set on this site)?
- Where is the cut off for you in drill diameter before moving over to hole saws?
I guess the same rule of thumb of 'you never have too many drills' is valid as for clamps, but I'm looking for a 'complete set' of descent drills that cover ground between 1mm and 50mm (or what ever is the largest size my Panasonic 12V drill can handle).
I'm wondering
