Sam Murdoch
- Apr 13, 2008
My question: How best to sand a tung oil floor finish in order to level off brush lap ridges and create an even surface without burning through the prior coats. My object is to just even the surface to prepare for a final coat? I am willing to sand with a hand sander like the ETS150/3 EQ. Better options? (I have an RO125 and I am pretty certain that this is not the toll to use in this case.) What type of Festool abrasive? Supporting info below. If there is no good Festool option I will likely opt for a hand sanding approach. This is not a job for air sanders or walk behind sanders.
The work issue today leads me to post this question to you folks with more experience with the Festool sander options: I have been applying a Carlisle Tung Oil finish to a 480sq.ft. wide plank pine floor that I just installed and stained. The temperatures have been in the 80°s with humidity pushing 60%. Each of 3 coats has been drying nearly as fast as I apply it. The first coat was done with a lambs wool applicator and too many starts and stops and drips never leveled out. Needed to sand the entire first coat by hand before applying the second. As I have not had the luxury of waiting for more favorable weather, I persisted and hoped for the best. I've done these floors in the winter and fall with great results and so, ever the optimist... The second coat went on and dried a bit more evenly than the first (cooler day). Today's coat, # 3, I applied with a brush and I knew as I was going out the door that this coat was never going to level out. In the morning I expect to find raised brush marks throughout that will compel me to sand all the little ridges before applying yet another coat. YES, I found the floor looking like an example of painterly fine art by an old master. If it was a painting on canvas I would be quite proud of my enthusiastic brush technique. [crying] I have called the finish manufacturer and got the go ahead to add Penetrol to the tung oil which should alleviate the flow out issues for the last coat. Wish I had thought of that sooner. In any event, I will wait until mid-week rather than sanding this very soft finish. I appreciate any advice you might care to offer.
