Packard
I built a screen door with four same-sized openings. However, my calculations were off and the bottom opening is about 1/8” over-size and the top opening is about 1/8” undersize.
So I ended up with three different sized screens.
I labeled the screens with #1, #2, #3 and #4 using a Brother label machine and the labels adhered well and were hidden when the screens were installed.
But efforts to label the openings fell short. The labels’ adhesion seemed tenuous at best.
Instead I bought a set of 1/4” high number/Letter stamps from Harbor Freight. I’m sure that these are not world class quality, but since they were intended for marking metals (including mild steel) and I was marking painted wood, my guess it will hold up rather well.
The stamped numbers were sharp and clear. I tried rubbing in some wax hole filler for contrast, but it did not go well.
Any suggestions on filler to add contrast to the numbers? The screen door is black, semi-gloss (Benjamin Moore High Build Regal Select Exterior.
The letter/number stamps cost $14.99. So not too bad.
Now if I can figure out how to keep the screen frames from bowing inward after installing the fabric, I will be golden.
