SGCrain
- Oct 8, 2014
Hi All
I'm a new Festool owner. So far I have a TS55, MFT3, Midi Vac and a bunch of systainers. I'm ready to move in to a sander or two and need some advice. I own a cabinet shop and have gone through the usual process of learning about sanding. We now use dynabrade type RO sanders with no dust collection. I have seen the 'green light'
with the Festool system and want to try some Festool sanders on a job we are starting that is alder veneer mdf core edgebanded cabinet doors. These doors will be stained dark brown. What sander or sanders, sandpaper and grit sequence would you guys recommend for this application? My main use would be for veneered products but we occasionally might use them on some face frames. We have a 2 head wide belt sander so I wont be doing any rough stock removal. I'm thinking the RS2E might be the last sander used in the process but I'm thinking of starting the process with an ETS125 or 150 (3 or 5 ???). We typically don't like to sand past 180 grit because we like a good 'tooth' for the stain and the lacquer to bite in to. Looking forward to participating more on this forum Thanks in advance!
I'm anxious to try some alder samples with the Festool products and with my current system and compare the results.
