I have been using the TS-55 extensively this week for ripping and cross cutting 25mm thick MDF Bench seats. (For a restaurant.)
The bench seat frame work is a basic 70mm x 45mm pine. Bottom plate, studs and then a top plate with the MDF attached directly to the framework.
All edges have been rounded over using a 6mm rounding over router bit.
I owned the Festool ATF-55 for 8 years and loved it. Then when I first used the TS-55, I was blown away that so many design flaws had been addressed and solved. A perfect example would be the spring loaded riving knife as opposed to the very dangerous fixed riving knife which I am sure scarred many a guide rail. (First day using the ATF-55, I scarred both of my rails!)
I love using the TS-55 with the CT-22 dust extractor, especially when I am cutting MDF.
Without dust extraction, the dust gets everywhere.
With dust extraction, you honestly would not know that I had been cutting MDF all day.
Anyway, I have a few small idea's for the next generation of the TS-55.
1. The ability to cut -1 degree.
2. The ability to cut to +50 degree's.
3. Cover plate should be 1 whole piece. No hole in the middle for the allen key/blade removal. (Obviously this requires a whole new design for blade changing.)
4. Connector rod for joining rails. I have lost count the amount of times I have forgotten to bring a straight slotted screw driver to tighten the grub screws. We need a quick joining connector rod. No extra tools required.
5. Make the saw slightly lighter if possible.
6. Make the motor slightly stronger if possible. I have been ripping through 35mm radiata pine and the saw has stopped half way through a cut. Wait 5 minutes and then finish cut. I cant afford to wait 5 minutes when working on contract. Yes, I was using a panther blade.
7. Plastic insert is set up for left handed people. I like to use my right hand to place the saw back in the systainer, but then have to swap to my left hand to get it in the systainer. (Very minor issue, but still something I would like to see addressed. Maybe they could give us the choice of left or right handed inserts.)
These are all minor issues for me, in general I absolutely love using the Festool saws, and I love telling people about them even more!
Please feel free to add to the list.
All new ideas, no matter how small are welcome, maybe the Festool Engineers will be reading this in the future and incorporate some of these idea's into the next generation of Plunge Saws.
Regards, Justin.
Regards, Justin.
