What's the best studfinder.
SittingElf
I've got an older studfinder that is not what I'd call super accurate.  I've drilled enough holes into the vacuum of space to recognize that my current studfinder is not exactly fully up to snuff.  The money I've spent on patching putty would probably be much better spent on a really good Studfinder.
What are you guys using, and what do you think is the best? (like Festool quality best)
Cheers,
Frank
Never used one myself but make sure it's not the same one grasshopper used to drill through his soil pipe  [eek]
Dave
Agreed on the magnet.  You can also tie a nut to a string and attach it to the magnet to act as a plumb bob when the screws are higher than can be easily eyeballed.
A tape measure.
Determine which side of the outlet box has the stud.  Do that with another box on the same wall.  If the measurement is divisible by 16 then your studs are 16" on center.  Simply measure from a known stud to locate the other studs.  This may not work when you get close to corners or under windows.
I don't trust stud finders.
Greg M said:
A tape measure.
Yes, agreed.
Best way is to find one like Greg says and then measure.
Tim
I just picked one up at Costco.  It worked great on the display but I have not tried at home yet.  It shows both sides of the stud at the same time.  Appears to be pretty slick.  I have never had good luck with the other ones sold at HD.
mike_aa said:
I believe the one at Costco for $35 is actually a rebranded Franklin Sensors.
I think you are correct.  I just went out and looked and it very close if not identical.
AWESOME!  Thanks a bunch guys.
The Franklin 710 looks like my cup'o tea! [tongue]  Not a single negative review that I could find. Excellent!
Cheers,
Frank [thanks]
MY WIFE !    Is the best "stud"  finder !    [tongue] [tongue] [tongue]
But seriously,  I have the Franklin 710.    It's the best stud finder I've used.
Eric
Indeed.
2,642 people gave the Hanson 5 stars.
Eric
LOL!  I was waiting for someone to say that!  I should have known it would be you! [big grin]
Mike A.
