- Nov 3, 2007
I have a Franklin Sensors 710 and it works great.
itasor said:I use the Franklin 710 (better than any other electronic stud finder, ever), then double check with the Hanson magnetic one -- they work well together.
Davej said:Never used one myself but make sure it's not the same one grasshopper used to drill through his soil pipe [eek]
Dave
How much money do you want to spend ?? I have this one.SittingElf said:I've got an older studfinder that is not what I'd call super accurate. I've drilled enough holes into the vacuum of space to recognize that my current studfinder is not exactly fully up to snuff. The money I've spent on patching putty would probably be much better spent on a really good Studfinder.
What are you guys using, and what do you think is the best? (like Festool quality best)
Cheers,
Frank
rvieceli said:Frank - I don't personally have one, but this one is supposed to the king of stud finders. It's from Franklin Sensors
http://www.amazon.com/ProSensor-710-Franklin-Sensors-Precision/dp/B0064EICKG/ref=sr_1_1?s=hi&ie=UTF8&qid=1412567045&sr=1-1&keywords=franklin%20stud%20finder&tag=viglink20245-20
Ron
SittingElf said:itasor said:I use the Franklin 710 (better than any other electronic stud finder, ever), then double check with the Hanson magnetic one -- they work well together.
That's the decision I've made, thanks to the responses in this thread! [smile]
Ordered both on Amazon.
Cheers,
Frank
WarnerConstCo. said:Find nails in trim (baseboards) check recept's for stud side, my knuckles an ear works really good.
Tinker said:WarnerConstCo. said:Find nails in trim (baseboards) check recept's for stud side, my knuckles an ear works really good.
That's been my way. I bought a stud finder once, used it once. the next time I needed it, the battery was dead so i had to go back to the old method of knuckle drill.
Tinker
Grasshopper said:Anybody use one of these: http://www.amazon.com/DEWALT-DCT410S1-12V-Inspection-Camera/dp/B0043XX89K/ref=pd_sxp_f_pt
After my "mishap" I am considering a pinhole camera of some kind to inspect inside the wall-
wow said:Grasshopper said:Anybody use one of these: http://www.amazon.com/DEWALT-DCT410S1-12V-Inspection-Camera/dp/B0043XX89K/ref=pd_sxp_f_pt
I have this one:
http://www.milwaukeetool.com/instruments/inspection-and-detection/2310-21
I can't believe how much I use it. It's one of those eye-opening purchases!
And thanks for reminding me - it is currently lying in a tool drawer, but I need to get it into a systainer.
