sucker 4 tools
- Jun 11, 2015
is there any fool proof set ups maybe home made that are perfect for repeat 90 degree cuts im cutting a lot of squares for cab's that need to be perfectly square
sucker 4 tools said:no mft and dont want to fork out for all the extra guides yet really, are they really worth having ? i have had good success with measuring and marking but just wanted to speed up the process and maybe attach some sort of square to the rail ?
MavDog said:I have been using this for several years and it works great. I keep it on a 1400 rail and used my Woodpecker square to set it to 90 degrees. http://www.amazon.com/DEWALT-DWS5028-TrackSaw-Miter-Gauge/dp/B001J32KMI/ref=sr_1_10?ie=UTF8&qid=1440950503&sr=8-10&keywords=dewalt+track+saw+accessories
sucker 4 tools said:is there any fool proof set ups maybe home made that are perfect for repeat 90 degree cuts im cutting a lot of squares for cab's that need to be perfectly square
SMJoinery said:sucker 4 tools said:is there any fool proof set ups maybe home made that are perfect for repeat 90 degree cuts im cutting a lot of squares for cab's that need to be perfectly square
It may seem expensive but if you have lots of cuts to do you should seriously consider buying the MFT3. It greatly speeds up this kind of work, easy to square and even easier to guarantee repeatable cuts plus you get a great assembly table.
I now have two which have paid for themselves many times over.
I use them for cutting sheets, assembly table, sanding table, extension table for saw, router table etc.
good luck.
Scott
