Painting my 28 Ft fiberglass boat will requires a 120/150 grit prep for epoxy primer.
Then 320 grit prep for first coat of two part paint.
The only other tasks for the sander will be removing paint/varnish from both wood
and metal surfaces.
Previous boat jobs were completed using a 5" Porter Cable that choked up
on the epoxy primer after a few minutes of use. I know my new
150 ETS hooked up to the CT 22 will do much better.
OK Get the 3mm (1/8") or 5mm (3/16)?
Thanks to all. Larry
and metal surfaces.
