antoniomcs
 - Dec 7, 2021
Hi everyone,
I'm in the process of buying a sander, but I don't know which one will be more suitable.
I work mainly with baltic birch plywood. So, I need to sand small pieces (6x12 inches, for example), as well as large pieces (12x70 inches, 20x20 inches, for example).
The plywood is bought directly from the supplier, so it's not really rough stock, and it's raw (it isn't painted, varnished or stained).
I need a sander to smooth it, and smooth between coats of filler and varnish.
Maybe one day I need to sand primers and between coats of paint, but not for now.
Occasionally, I might need to sand a solid wood kitchen table top, and between coats.
After reading several opinions and reviews, I can't make my mind if I need a 5 inch or 6 inch, 3mm stroke or 5mm stroke.
I was looking at the ETS EC. Is this a good option, or are there other better options?
Grit range: 120-320
I can afford only one sander.
What do you recommend, according to my needs?
Grit range: 120-320
