Frank-Jan stated in another thread that the PDC held up better over time and in heavy use, and looked better after 4+ years on a construction site than the other model did.
http://festoolownersgroup.com/other-tools-accessories/t183-vs-protool-pdcdrc-18-4-vs/msg212079/#msg212079
And this thread more or less concludes that the PDC + CXS is a perfect combination.
http://festoolownersgroup.com/festool-tools-accessories/agonising-over-the-drills/msg321219/#msg321219
Anyway, time to go back to the dealer and try them both out once more. I think it's going to be either the T18+3 or the PDC18/4 Quadrill. It's occurred to me that there have actually been times when there hasn't been power available close by, so maybe going with the LiIon version rather than corded isn't such a bad idea after all.
Based on the latest cordless Festool offerings (circle saw, jigsaw, drills), it could appear that they are moving towards 18v as standard across the range, and with the weight difference between 15v & 18v being negligible, I think having the added power and higher capacity makes sense. Hopefully it will keep things compatible for some time into the future as well.
It appears at any rate that many people get by with the CXS for most tasks, and bring out the heavy duty stuff when needed. Which is pretty much what I was planning.
Thanks again for the comments and suggestions.
BeardMan said:
Alex said:
About 4 years ago I went along with my nephew to buy him a Festool drill. He really liked my T15 and is a Festool fan so he wanted one also. When we were in the store the salesman persuaded him to get the Protool PDC 18/4 instead.
He gave me the PDC for a while to thoroughly test it, and so I did. I liked the drill mostly because it was so fast. 3800 rpm really speeds up your work when you're drilling or screwing. While it didn't have the control the T15 has, it was a very smooth drill anyway.
Now I'm painting a house of my nephew and he has his tools there so I am using the PDC 18/4 again. I can't believe how crap it is now, like an old rustbucket. The motor sounds and feels like a rusty landmower, the switches on top are very hard to move, and taking the battery on and off needs some serious effort.
In contrast, my T15, which is 4 years older and probably used a lot more, is still in the same condition as when it was new.
Not sure if my nephew seriously mistreated the PDC or if it's the build quality. It doesn't look bad on the outside, you can just feel it's bad on the inside.
Hm,interesting!
I'm looking for a new drill now (for heavy duty) to add to my CXS (light duty), and my choice is between T18 and PDC18.
Looks like PDC can't withstand a heavy/rough work?
To bad.
How is T18 compared?
P.S. May be this stuff is more heavy duty? Who knows... -
